I was wondering If anyone has had a problem using the Moroso front drag springs in there car. I have a set in my 66 nova, have only used them two seasons and one has collapsed, the one on the passenger. That side sits down about 3 inches lower than the drivers side.
Terry Waldron 5619 K/S |
Any help with this problem would be appreciated. Do not want to take my stocker out until I get this fixed. Should I just buy another set of springs again?
5619 k/stock
Terry ,Ichange the moroso springs in my car every other year,they will collapse and lose spring action,there is a solution to that problem,when your car is at home in the garage ,jack the front end up by the frame and let the weight off the springs.Jeff Lee posted awhile back about a place here in Illinois that builds springs,sounded like a better deal than moroso,but as always everyone bashed him for offering a better solution,,somewhere I read he was banned from this site but if someone could put you in contact with him I think it would be worth your while.
Thanks I guess I will just put another set in, that sounds about the easiest way to fix it .
5619 k/stock
Liked 333 Times in 180 Posts
Try Jeff @ 602-418-9797
