Old 06-12-2007, 10:16 PM   #1
JOE B
Default after the burnout ????
i 've noticed the rubber buildup on the 1/4 panels is more on one side then the other . been to 3 diffrent tracks so i don't think its the burn out box ?? the right rear has more buildup then the left rear ??
the same thing with a m/t slick or m/t drag radial . cars is s/s leaf spring..any thoughts ?? thanks joe b.[:-confused2-:]
JOE B is offline   Reply With Quote
Old 06-12-2007, 10:31 PM   #2
Chris Hill
Liked 244 Times in 26 Posts
Default
Have you had the car on four wheel scales?
Does the car pull to the left at launch?
I'd bet your heavier on the right rear vs. left rear. An easy way to tell is have someone watch your burnout from behind. The heavier tire generally will smoke first.
Chris Hill
Spec 125 Light
Chris Hill
Old 06-12-2007, 10:44 PM   #3
NovaMan
NovaMan's Avatar
Default
Posi or spool?
~Pete
1970 Nova
12.653@105.43
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
Old 06-12-2007, 11:30 PM   #4
JOE B
Default
Chris Hill
Spec 125 Light
no cars leaves straight .
scale wieghts where front 52% /rear 48% . left rear 719 lbs/rite rear 714 lbs. i will have somebody look for that this weekend .
novaman . car has a full spool .
thanks guys
Old 06-13-2007, 02:11 AM   #5
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default
what kind of car? all the novas i've had... one slick sets closer to one side then the other......could be why one side has more rubber then the other?
novamoation
Old 06-13-2007, 07:39 AM   #6
JOE B
Default
novamoation
PINTO
