Old 08-01-2025, 10:19 AM   #1
Joey Bohannon
Liked 61 Times in 22 Posts
Default 2007 Cobalt Super Modified
2007 EASTEXAS CHEVY COBALT Comp/SS
*Pro stock 4 link & anti roll
*TBM brakes all around
*Strange struts with fast shock valving
*40 spline m/w axles
*M/W center/Lamb support Indy gear set up
*Penske rear shock air operated
*Milodon fuel pump with new fuel lines
*Racepak smart wire system
*Racepak all 8 oz?s & every sensor you can get from wheelie bars to temperature
*MSD grid
*Precision shifter (forward pattern)
*Car comes with pro jacks & pump
*Racing radios & charger come with car
*Spare drive shaft, springs, lifters, wheels and tires. Also wing to put in SS. To many parts to list.
*Push bar also comes with car for your golf cart
*Third pedal in car if needed
MOTORS
*E/SMA or HA/A classes
1 motor 322 splayed valve built by (RCE) motor will be fresh with 0 runs. Motor has 2 carb or 1 carb set up. Whatever class you run. Motor has the best of the Best parts. Jim from (RCE) will confirm.
1 motor 322 SB2 built new 1.5 yrs ago by (RCE). Everything but block is brand new. CFE heads & intake. Motor has 2 carb or 1 carb set up also. Best money can buy!!
TRANSMISSION
Pro Trans with adaptor 254/154 ratio with 4 passes currently/ freshen up from Larry Allen. Has all the good clutches.
Pro trans with adaptor 247/151 ratio that is fresh from Larry Allen.
Coan bolt together converter with multiple stators.
This car has the best parts money can buy. Has won multiple Division/National events. Will sell the car with one motor or both.
Not selling Rolling!
One of the nicest Cobalts out there. (NO TRADES)
Everything goes $180,000
1 Motor & Trans(either motor) $150,000
Contact: Matt Alvey 502-790-4429, matthew.alvey@trane.com
Joey Bohannon is offline   Reply With Quote
