Old 05-18-2025, 02:08 PM   #1
my69396
Liked 46 Times in 20 Posts
Default Front tires Pros and Cons
Ds2 vs Drag specials vs Sportsman fronts vs Goodyear front runner any thoughts?
my69396 is offline   Reply With Quote
Old 05-20-2025, 10:55 PM   #2
Rory McNeil
Default Re: Front tires Pros and Cons
Maybe I am just unlucky, but on my cars, I have found that the M/T "ET Drag" , Hoosiers, and Goodyear front tires are bad for not holding air all that well, a buddy uses the M/T Sportsman fronts, they hold air very well, but are quite a bit heavier. I have found that the Moroso old style "Drag Specials" hold air very well, and also seem to virtually never wear out the treads, unlike my MT E/T Drags, Hoosiers, and Goodyear "Frontrunners". I have also had good luck with the M&H front tires, but have never used the Moroso DS2 models. Out of all the brands of front tires that I have used over many years, my favorite is the Moroso Drag Specials, but they are only available in 3 diameters, which may not make them ideal for many racers.
NHRA 6390 STK
M/S 85 Mustang
Old 05-21-2025, 02:45 PM   #3
340Cuda
Liked 805 Times in 341 Posts
I also have had very good luck with the Moroso Drag Specials, replaced them only because of age. The "middle size" was perfect for me.
A very long time ago I used Firestone front tires that held air fine but wore out quickly.
Old 05-21-2025, 04:24 PM   #4
nickh
nickh's Avatar
Liked 692 Times in 205 Posts
When I sold my bracket Nova in 2019 it had Moroso's on the front that were 12 years old and still looked brand new and never lost air. However I did purchase a new pair and they went with car.
Old 05-21-2025, 10:03 PM   #5
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
I too have the Moroso Drag Specials. Never lose air and look new on the tread and sidewall.But they are older than I like so am putting on the Hoosier 18107's which are exactly the same diameter as the 7.10x15" Moroso's.
55 Chevy is offline   Reply With Quote
Old 05-22-2025, 09:21 AM   #6
rebelrouser
Liked 8 Times in 3 Posts
when you mount your tires rub some baby oil on the insides and they will all hold air just fine, at least it has always worked for me.
rebelrouser is offline   Reply With Quote
