Old 04-10-2025, 08:48 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default steering shaft cover
new GT build needing the alum. steering shaft cover ive seen around...any idea who would have them or advice? tks
Old 04-10-2025, 10:00 AM   #2
Hacksaw
Liked 314 Times in 177 Posts
Default Re: steering shaft cover
I use 2" OD alum tube, .062" on the wall. Fab an upper and lower collar ( Nylon or similiar) to suit the 3/4" shaft and use 3 rivets to hold the collars in position. Also notch a piece of 1 1/2" square tube, drill holes and weld as a mount .
Old 04-10-2025, 02:19 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
If you buy the kit from one of the chassis companies they come with everything you need to install it. I think I got mine from Jegs.
Mike Pearson 2485 SS
