Old 12-21-2024, 03:16 PM   #1
john billups
Default Q jet power piston spring
Need a little help with the best spring . I have s spring set with 5 spring different colors and length.
80 g body w / 305 .
My problem is the motor wont idle. It acts like it go's rich and dies. I have vary low vacuum so I'm thinking the power valve is opening at idle and
dumping fuel.
My question is should, I use a tall spring or a short spring or just test till one that works
thanks, John
john billups is offline   Reply With Quote
Old 12-21-2024, 03:32 PM   #2
Danny Ashley
Liked 110 Times in 29 Posts
Default Re: Q jet power piston spring
It is a street car or racecar?
Danny Ashley is offline   Reply With Quote
Old 12-21-2024, 03:39 PM   #3
john billups
stocker. w/ stocker cam short lift long duration.
Old 12-21-2024, 06:15 PM   #4
MR DERBY CITY
Liked 7,939 Times in 1,520 Posts
Could possibly be a vacuum leak ?? Has the intake been removed lately ?
Old 12-21-2024, 07:02 PM   #5
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
Spring shouldn’t affect idle. Power piston is tied to main circuit not idle circuit if pulling fuel from main circuit at idle throttle blades are to far open.
outlaw is offline   Reply With Quote
Old 12-21-2024, 09:55 PM   #6
john billups
Checked for vac leak w/ smoke machine.
As for the pistons. I thinking maybe a little pull over .
Well I'll put it back together as it's a backup and work on it next spring.
thanks all who chimed in.
John B645
Old 12-22-2024, 07:22 AM   #7
Danny Ashley
PM sent
Old 12-22-2024, 12:34 PM   #8
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Put flat edge on top base sitting upside down. Must be good and flat.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 12-23-2024, 09:09 AM   #9
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
Get a drinking straw, cut it down to about 4? long. Place it in the vent stack
at abslight angle to catch the power piston/primary metering rod hanger arms. Note the length sticking up. Now start the engine. It should pull the power piston down and the straw with it. If it goes down and stays down
At ?idle? (yes I understand it won?t idle well on its own but you get the idea) then that?s not your problem.
Have you drilled the holes in the primary blades yet?
Kp
Old 12-23-2024, 09:23 PM   #10
monte385
Liked 27 Times in 19 Posts
Get rid of PP & rods & block the vac. supply, reduce jet size.
monte385 is offline   Reply With Quote
