Old 08-29-2024, 09:25 AM   #1
Ken Parkman
Liked 4 Times in 3 Posts
Default Cast crank for Super Stock?
Hi All. I want to jump in with you guys into Super Stock with a slightly oddball combination that does not have a steel crankshaft. This is a small V8 so will spin reasonably fast. I possibly could destroke a longer stroke steel shaft, but it would be quite a bit of effort.
Just looking for similar ish experience, which clearly is not directly comparable. Do the 289 Ford guys use a cast crank and does it hold up? Other combinations?
Ken Parkman is offline   Reply With Quote
Old 08-29-2024, 11:21 PM   #2
Jrh5220
Liked 28 Times in 17 Posts
Default Re: Cast crank for Super Stock?
A cast one is fine.
Jrh5220 is offline   Reply With Quote
Old 08-30-2024, 07:58 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
Built quite a few 680 -720 HP Bracket race BBC with cast cranks 2.200 rods. Turned a few to 2.100 rod journal for SS. The 2.100 eventually cracked.
Adger Smith (Former SS)
Old 08-30-2024, 09:42 AM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
Ken, If I am correct in my assumption about the combination you are talking about, you could find an ArmaSteel shaft which would be somewhat better. But in any case, the cast crank will be more than adequate and will survive the 8000+ operation range you are anticipating.
Old 08-30-2024, 11:16 AM   #5
Stan Weiss
Stan Weiss's Avatar
Liked 732 Times in 383 Posts
I see in the Indy thread that 2 of the 4 stockers in the barn are Pontiac. Does anyone know if they are running a cast crank?
Stan
Old 08-30-2024, 12:28 PM   #6
ss3011
ss3011's Avatar
Liked 238 Times in 113 Posts
I ran my 455 SD Pontiac in Super Stock, and it has always had a Cast crank/ The rules for SS allow you to run an accepted aftermarket crankshaft, so that may also be a option.
Old 08-30-2024, 01:24 PM   #7
Ken Parkman
Thanks guys. I'd already started down the road with a stock cast crank, but just started to second guess myself. Time to keep going. Dwight has assumed right on the combo, and unfortunately there is minimal aftermarket support, and no cranks are available.
Old 08-30-2024, 02:08 PM   #8
Gary Smith
Gary Smith's Avatar
Liked 132 Times in 30 Posts
Give Jim Harrison a shout at Fast-Shaft...(618) 445-2556
Gary Smith
"another broke racer spectating"
Gary Smith is offline   Reply With Quote
Old 08-31-2024, 08:02 PM   #9
Kirk Morgan
Liked 78 Times in 42 Posts
Kip Martin ran a cast crank and stock rods in his Super Stock Mustang with no problems at all.
Kirk Morgan is offline   Reply With Quote
Old 08-31-2024, 08:42 PM   #10
nolongerracing
Liked 72 Times in 27 Posts
Stan
I know for certain that the J/SA 400 Pontiac has a stock cast crank.
nolongerracing is offline   Reply With Quote
