Old 07-07-2024, 03:08 PM   #1
Liked 10,647 Times in 2,207 Posts
Default Best Way To Check End Gap On 3 Piece Oil RingI
I'm not satisfied on the repeatability of my measurements. I need some ideas and recommendations on techniques to incorporate.
Thanks!
Old 07-07-2024, 03:27 PM   #2
Liked 1,737 Times in 395 Posts
Default Re: Best Way To Check End Gap On 3 Piece Oil RingI
Thanks!
I use a standard squaring tool to check the gap on the rails, same as a compression ring. I'm not really aware of a way to check the gap on the expander. I check the drag on the oil ring assembly by itself to verify there's not a problem with the expander. The exapander on the Speed Pro SS-50U is what set the tension on those rings, the expander on the Hastings oil ring just holds the rails in place, the rails set the tension.So I don't mess with them.
Old 07-08-2024, 07:33 AM   #3
Thank you
