Old 07-05-2024, 04:47 PM   #1
jcw31
Liked 6 Times in 6 Posts
Default ppp shifter
Have a friend with a ppp reverse pattern shifter . It has a problem going 1st to 3rd ,it seems if pushed forward hard it bypasses 2nd with what seems has no positive stop for it . Anybody else have this headache ?
jcw31 is offline   Reply With Quote
Old 07-05-2024, 06:01 PM   #2
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: ppp shifter
Same problem but on a Cheetah shifter. Let wd40 dribble down shifter cable and fixed for 2 years now. I lost 2 rounds because of this problem
Old 07-06-2024, 09:34 AM   #3
jcw31
Not the cable , doesnt seem to have a positive stop between 2nd and third. Wondering if anyone had/ fixed the problem.
Old 07-06-2024, 09:37 AM   #4
GUMP
We had this problem. Coan sent us a plate to stiffen the detent arm. According to Foley, it is now working fine.
Daren Poole-Adams
NHRA Stock/SS 2007
GUMP is online now   Reply With Quote
Old 07-07-2024, 04:21 PM   #5
Barry Polley
Guest
Posts: n/a
I’m sure you have checked the lever ( does it have multiple holes) for alignment ( pin moves freely in and out of lever) in each gear.? I have the same shifter and it’s positive every time.. I don’t hit mine but I’m sure you could.
Old 07-08-2024, 06:05 AM   #6
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: ppp shifter
Good morning Jeff and to all,
When I upgraded from the PG to the TH200 I kept missing second gear with my Turbo Action Shifter. Not the shifters fault - driver error. Old habits are tuff to stop and tougher as we get older. Joe DeMarzo and Billy Marshall got me hooked up with a Hurst Quarter Stick shifter and once I got the feel for it , the shifter is working perfectly. My trans shift forward, so I hit it for Second, then grab and hold the lever and make the 2-3 shift. just make sure to let go of the lever once you've made the gear change. If you hold the stick and rock it slightly, you can unlock the neutral gate and go into neutral.
Thats worked for me , and I hope that helps you.
Have a Good Day!
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 07-08-2024, 08:29 AM   #7
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
This thread is about the PPP shifter not the Cheetah shifter that has performed flawlessly for 12 years I used it, never once did it not shift into 2nd gear with my turbo400, same cable as day 1 install and no maintenance ever done to the cable or the shifter. Just saying.
Old 07-08-2024, 09:07 AM   #8
Jeff Stout
Ok I'll play. The first sentence on my thread. ( Same problem but on a Cheetah shifter). I mentioned as it had exact problem. The cables stiff and on the 1 2 shift the shifter would not hit the 2cd gear detent and the spring would push shifter over and miss the detent and continue into third. Lubed cable and that stopped it.
By the way this shifter was first install in 1993 and I bought it at a swap used. Second car in 2002. I would say your 12 year old shifter is brand. Just saying.
Old 07-23-2024, 12:38 PM   #9
House of Darts
Liked 20 Times in 15 Posts
I'm fighting a similar issue with the shifter hitting 3rd but the trans is not fully engaged. PPP solution was to lube the cable(which I did) or get a longer cable. The PPP seems to be sensitive to the bends in the cable.
House of Darts is offline   Reply With Quote
Old 07-08-2024, 09:09 AM   #10
Jeff Stout
By the way this shifter was first install in 1993 and I bought it at a swap meet used. Second car in 2002. I would say your 12 year old shifter is brand new. Just saying.
