Liked 25 Times in 6 Posts
For ss 904 is there a air/ electric / nuclear/ mind controlled/ shifter that works with a tran brake/ clean neutral valve body
Liked 3,114 Times in 959 Posts
PPP w/ clean neutral and air shifter works great on my 904.
ppp co2 with biondo controler
Liked 114 Times in 29 Posts
M&M shifter w/air will work great also
thanks all
Paul Forte was also working on a clean neutral version, you might call TurboAction if you can?t find a PPP. Brad and his Dad worked tirelessly to keep up with demand, IMO the M&M represents patent infringement. It?s been a while since I?ve talked to Brad but his tech support was awesome in fixing an issue I had with a unit installed by a previous owner.
#7 | |
Patent infringement for M&M? Please explain... |
IMO their similarities are significant enough to say they copied an existing design without introducing any enhancements to that design. If that?s not the case I?m receptive to being corrected ( I?ve been married for almost 50 years so definitely not adverse to correction).
#9 | |
To which company are there similarities? It doesnt matter to me either way, I have one already, i just was curious |
Brad Ochampaugh and his Dad developed the PPP over 30 years ago and it?s proven to be the dominant shifter in this application, subsequent similar offerings from other manufacturers should have expressed licensing agreements which I don?t think is he case in this instance.
