Old 05-06-2024, 09:57 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1962-69 SBC & BBC Parts
1962 3782461 heads both dated A-5-2 $1,000
1963 327 engine including the block, steel crank, rods, intake, valve covers, air cleaner, bolts, pulleys, water pump and mislc. will need one sleeve and is standard bore asking $1000 or will separate out.
1969 #3927186 heads 1.94 and 2.02 with the following dates
I-18-8 & I-21-8 w/ 1.94 valves $800
K-5-8 matching dates w/ 1.94 valves $800
K-2-8 single 2.02 converted to screw in studs $500
C-10-9 single 2.02 $500
E-18-9 single 2.02 $500
D-2-9 & D-11-9 all machined converted to screw in studs ready to build $1,000
G-25-9 matching dates 2.02 $900
H-27-9 single 2.02 $500
3919840 square port heads with the folowing date codes
E-18-7 & E-23-7 $2,000
A-10-8 & A-12-8 $1500
J-29-8 rebuilt $800
I-18-8 $750
A-2-9 $750
C-25-9 & E-12-9 $1500
All heads sbc and bbc heads have been cleaned and magnafluxed. I can ship if you cannot pick up and located in bowling green ky. I can be reached directly at 330-770-2517 for any questions or pictures needed.
dlv4540 is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
