Old 03-08-2024, 10:48 AM   #1
Stk4996
Default Converter/trans issue
Few weeks ago running my car first run 60’ was where it should be but then come up on the 1-2 shift it hesitated but shifted, then the 2-3 did the same thing hesitated like it was on a limiter but shifted but then wouldn’t make it past 1000’ as it wouldn’t rev over 7,000… Checked things thinking it was electrical made another hit and when it left, it left like it was in high gear. Coasted down the track and shifted the car by hand and it shifted fine.
I thought it had broke a converter, got home sent Converter to ATI they called yesterday and said converter is fine. Tore transmission apart and it looks brand new other than the Static (plastic) washer for the input& output shafts end play clearance was destroyed. So it had about 100 thousandths or more end play.
Anyone else experience something similar? Or could that shaft clearance being so much cause some oil passages to be blocked restricting flow etc?
This is a Metric 200 Transmission in a 97 Firebird LT1 set up.
Thanks
Stk4996 is offline   Reply With Quote
Old 03-08-2024, 12:24 PM   #2
Liked 5,071 Times in 1,932 Posts
Default Re: Converter/trans issue
How was the back half clearance?
Old 03-08-2024, 12:28 PM   #3
Stk4996
It was the same as the front
Old 03-08-2024, 12:38 PM   #4
.100 ? ..How did it get that way?
Old 03-08-2024, 01:43 PM   #5
RJ Sledge
Liked 288 Times in 90 Posts
I hope you find the issue.
May sound stupid, but are you sure you have enough Tranny fluid?
Maybe you installed a deeper trans pan?
Correct length pickup on filter?
Band adjustment?
RJ
RJ Sledge is offline   Reply With Quote
Old 03-08-2024, 09:58 PM   #6
Originally Posted by RJ Sledge View Post
Band adjustment?
RJ
RJ, The 200 doesn't have an adjustable band like a C4 would. It has to be set up and clearanced in the servo .
The stock anchor pin can shear off, and there is a better one in the aftermarket.
But you bring up a good point.
If the front half clearance is excessive, then the direct drum can **** (that would be **** , for the sensors) (how about go cokeyed?) and rock , and maybe cause the sealing rings to fail.
Maybe we'll find out when our friend comes back. ;-)
