Liked 72 Times in 36 Posts
Does the electric radiator fan pull air across the radiator from out side of the car
or does it push air to the outside of the car thru the radiator? I'm wiring the fans now and i was wondering how to wire them. Thank You Kenney Kelley |
Pulls through rad. Towards the engine.
Or if you have the fan on the other side, push it towards the engine
Liked 138 Times in 51 Posts
I've always been under the impression that an electric fan mounted on the "inside" and pulling air from the front into the engine compartment, does a more efficient job of cooling.
It depends if you have enough room on the inside of the radiator. But I believe most fans that mount on the radiator simply require the wires to be swapped to change the direction/rotation.
LOCOMOTION Racing |
Liked 10,909 Times in 2,256 Posts
When racing the truck I was told that I had to have a fan. I had a stock water pump with the standard tooth belt and auxiliary 12 volt motor. Tech said go buy a fan and I did and install it. The fan added about 12 OZ to the nose of the truck. It was not any faster or slower with the fan and with the engine being a v6 the blades were so far away they did not generate any air flow across the radiator core.
But to race I had to follow instructions. |
#5 | |
Liked 1,110 Times in 304 Posts
It was at Indy. Who it was I don’t remember.
