Old 02-28-2024, 11:42 AM   #1
e vassar
Liked 272 Times in 108 Posts
Default LS Flexplate question
I bought a ATI 915543 flexplate for my LS T350 only to find out it won't work because the LS crank is a little shorter out the back of the block.
So went with Jegs 601080C it has sort of a bell shape for the clearance. I do plan to go with a metric 200 at some point, so my question is..which flexplate works with the metric 200?
Thanks
Old 02-28-2024, 03:24 PM   #2
Jason Shepard
Jason Shepard's Avatar
Liked 114 Times in 29 Posts
Default Re: LS Flexplate question
That same Jegs plate will work with both TH350 and 200
Jason Shepard is offline   Reply With Quote
Old 03-01-2024, 12:02 AM   #3
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
The short crank LS engines need a pilot spacer to mate to the converter, or have your converter built to the LS length. Using a spacer allows the use of any typical aftermarket converter
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 03-01-2024, 02:58 PM   #4
1legjerry
Liked 72 Times in 15 Posts
Meziere FPS174 and FPS174A will allow you to use any standard Small block or BBC converter.
1legjerry is offline   Reply With Quote
