02-19-2024, 08:06 PM | #1 |
Liked 151 Times in 42 Posts
12 Bolt Chevy Rear 5.00 Pro Gears
I have the rear end that I pulled out my 1969 B/SA Nova. I had to quit racing. It started as an Impala housing. Mark Williams 35 spline axles with a lightweight spool,Richmond 5.00 Pro Gears, complete assembly with drum brakes. Dana spring perches. The width from axle flange to flange is 60 inches. The housing was done by a professional chassis shop with the Mark Williams weld on ends with drop plates. No C-clip eliminators. This assembly has no issues, it is ready to go. I used the Weld Alumastar wheel 10 inch with 6.125 backspace. $2500 firm. PM me if interested.
