Old 02-16-2024, 02:42 PM   #1
Dave1695
Liked 15 Times in 11 Posts
Default measuring wheel run out
I want to check my front wheels for run out perpendicular to the axle. With a dial indicator set against the outer edge of the rim just above the lip, I can turn the wheel by hand to measure run out,but do not know the acceptable plus/minus tolerance I should have. Anyone have experience in this area? These are Weld Draglites 15 X 3.5. Thanks
Dave1695 is offline   Reply With Quote
