Old 02-14-2024, 07:24 PM   #1
BTR69
BTR69's Avatar
Liked 74 Times in 24 Posts
Default 4 speed tranny gear difference
Good evening. With a 4 speed manual tranny, how much difference would I see going from a 3.19 low gear, (written down, looks like it could be 3.17 or 3.19), to a 3.29 low gear? I'm pretty new to manual transmissions, so I have a pretty steep learning curve I expect. Thanks.
William Kilduff
1970 Barracuda (still under construction, indefinitely)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
Old 02-15-2024, 07:54 AM   #2
james schaechter
Liked 1,428 Times in 296 Posts
Default Re: 4 speed tranny gear difference
This really depends on the combination and some factors like hp, weight, tire size, etc. if you are talking about a SS/C with a rat motor, I personally think 3.29 is likely to be too low of a gear if the rear gear is optimized already.
A small block stocker would love a 3.29 on the other hand.
James Schaechter 3163 STK
Old 02-15-2024, 06:41 PM   #3
BTR69
BTR69's Avatar
Thanks for the input. I came across one I was considering to pick up as a spare. I'd end up having to spend more money on it to make it what I feel I need. Decided to wait for a bit.
William Kilduff
1968 Camaro SS/C
