Old 01-03-2024, 02:00 PM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default Coil over spring recommendation
Removing leaf springs and 70’s sliders from Chevy2 wagon super stocker. Ladder bar car weighing 1635lbs on the rear. Need spring recommendation rating for coil over. I already have coil over shock without springs. Thanks.
Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 01-03-2024, 06:59 PM   #2
SSDiv6
Default Re: Coil over spring recommendation
Ed
Contact Marty Rinehart at Rineharts Performance.
Old 01-03-2024, 11:04 PM   #3
Tom Meyer
Liked 354 Times in 120 Posts
110 on mine with just under 1500 on the rear. Tom
Tom Meyer 5240 SS Stock ???
Old 01-04-2024, 02:21 PM   #4
Ed McLawhorn Jr.
Thanks Tom!
Wagon going on major diet this winter. Working on removing 165lbs overweight for SS/La. Starting with replacing rear end and leaf springs removal.
Old 01-04-2024, 07:54 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,959 Times in 593 Posts
Makes a difference with the length of the shocks. Longer shock’s less spring rate.
Mike Pearson 2485 SS
Old 01-05-2024, 09:19 AM   #6
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
I can get you what you need. Call me at Rineharts Performance. 717-793-6819
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 01-06-2024, 04:53 PM   #7
CMcAllister
Liked 921 Times in 260 Posts
Rear spring rate is a tuning decision. Typically, there will be 3 or 4 different rate springs that will hold the car at the desired ride height, with different amounts of compression and energy stored to get there..
Lighter springs with some energy stored by being compressed will make it easier to get the housing out and apply the tire than heavier springs. Just as a light spring compressed to hold ride height on the front will promote separation.
Torque, stroke, gear ratios, trans type, tire type, suspension type, are a few of the things that play into that decision.
Old 01-06-2024, 05:20 PM   #8
CMcAllister
Old 01-06-2024, 11:11 PM   #9
Ed McLawhorn Jr.
Thanks everyone. Marty has springs on the way to NC.
