Old 12-24-2023, 08:18 PM   #1
Eman
Liked 133 Times in 76 Posts
Default Keeping heat in oil??
Any tips or tricks for keeping heat in the oil? After installing a temp sensor in the oil pan I was pretty surprised to see how much oil temperature dropped as I cooled the coolant down between rounds. I have a stick on pan heater but have only used it before making any passes to warm up the oil.
Old 12-25-2023, 06:08 AM   #2
Rick J
Liked 73 Times in 37 Posts
Default Re: Keeping heat in oil??
You can chill the water and heat the oil all you want, by the time you're staged they are both going to be approaching 100°F.
Why not just run a lighter oil? That will duplicate your cSt rating without having to heat the oil at all.
Rick J is offline   Reply With Quote
Old 12-26-2023, 02:47 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,970 Times in 596 Posts
I use my pan heater in cooler temperatures. I do it more for consistency than performance. Racing is so tight now that a hundredth can make the difference between win and loss. During the summer here in D2 the oil stays pretty warm between runs.
Mike Pearson 2485 SS
