Old 12-23-2023, 09:50 AM   #1
Todd Ewing
Liked 20 Times in 4 Posts
Default Yard sale
SHOP CLEAN UP
1. 375-396 steel head engine - original Koewn engine - stock block, je pistons, carrillo rods, schubeck lifters, total seal rings, comp cam, comp rockers, pac springs. moroso oil pan, quick fuel carb, moroso water pump, msd distributor and wires, coated headers for 1st gen camaro/nova.........NEW PRICE 12K COMPLETE!!*********READY FOR IT TO GO********
Engine was in a car that i purchased and I have time slips of .85 under in june from joliet in b/s.I have removed the pan to inspect and resealed the pan and primed the engine.
2. Complete Jerico combo - dr4 trans (3.08 low) pistol grip shifter - Quick time bellhousing, Advanced Single disc clutch (fresh from advanced 4/22 with ZERO runs since freshened), aluminum flywheel, $5k for complete setup******SOLD*******
****The engine and trans combo has very minimal runs since new.****
3. TH200 trans - Turbo Action - NON auto 1/2 - 2.75 low, i purchased trans new as a spare and it only has about 30 runs on it since new. Ready to go and needs nothing******* SOLD ********
4. TH200 trans - Select Trans built - AUTO 1/2 - 2.75 low, completely fresh with zero runs since ed went through it, all lightweight parts - METRIC INPUT SHAFT - $2500......NEW PRICE *****$2000.00******
5. Complete original 327 2 barrel engine and drivetrain out of a 1969 camaro - complete engine, manifolds, trans, convertor, driveshaft, 10 bolt rear, EVERYTHING!! - this is the original engine and drivetrain out of the car i purchsed! $ SOLD
call or text Todd ewing 256-755-0703...........location is north alabama
Todd Ewing is offline   Reply With Quote
Old 12-23-2023, 03:59 PM   #2
chassis1
Liked 3 Times in 1 Post
Default Re: Yard sale
Thanks Bones
chassis1 is offline   Reply With Quote
Old 12-24-2023, 11:03 AM   #3
Cdncarnut
Cdncarnut's Avatar
Liked 45 Times in 28 Posts
You have a PM.
Thomas
NHRA 1959 D/SA
Cdncarnut is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
