Old 12-20-2023, 08:08 PM   #1
Steve Wilson
Steve Wilson's Avatar
Smile 1970 Nova less motor and trans
1970 Nova – Rolling Less Motor and Trans, Clear Tennessee Title in My Name (You Could Make it a Pro Steet or SS Car if you wished.) Tubs and flooring are steel Not aluminum. Solid Car – No Rust, Set up for BBC and a Powerglide, 3100 LBS., Aluminum Radiator, Fiberglass Bumpers, Fiberglass Cowl Hood (Hinged Type), New Stock Style Steering Box, Lemmons Headers, Turbo Action Shifter with Electric Shift, Delay Box Stand, Smith Racecraft Mechanical Gas Pedal, 4 Wheel Wilwood Disc Brakes, NHRA Certified 10 Point Cage, Window Net, Auto Meter Gages, Auto Meter Tach, Aluminum Drive Shaft (Dyno Tech), Chris Alston Chromemoly Fab 9 Ford Rear End Housing, 40 Spline Moser Axles, S&W Back Half Frame, Ladder Bar Set Up, AFCO Coil Over Rear Shocks, Magna Fuel Pump and Filter, Aluminum 4 Gallon Fuel Cell in Trunk, 14.5 x 32 x 15 “W” Slicks, Weld Drag Star Wheels. wilsonracing2092@bellsouth.net or
901-493-5876 Steve $29,500 or best offer.
Steve Wilson is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
