Old 12-15-2023, 10:25 AM   #1
Weekend Racer
Default SS/valves springs
Time to replace valves springs. Plan on PSI DR424RML. SBC, SS engine iron head. What are yours tought ?
Thank You!
Weekend Racer is offline   Reply With Quote
Old 12-15-2023, 02:25 PM   #2
Hacksaw
Liked 309 Times in 173 Posts
Default Re: SS/valves springs
Seems too light on pressure to me. At 250 lbs. on the seat, if you lose 20 after break in .....
Old 12-15-2023, 04:45 PM   #3
SpeierRacing
Liked 70 Times in 23 Posts
I use a PAC 1356 on all new heads or freshens I do. On my personal engine I used a Manley 221420 but set them up taller because I have more lift.
SpeierRacing is offline   Reply With Quote
Old 12-16-2023, 07:54 AM   #4
Rick J
Liked 73 Times in 37 Posts
Thank You!
Not near enough info to make a recommendation -
Valve weight ?
Lobe duration @ .020" minus lobe duration @ .050" = ?
Rocker ratio ?
Peak rpm @ the stripe ?
Rick J is offline   Reply With Quote
Old 12-16-2023, 10:28 AM   #5
Weekend Racer
You have PM
Old 12-16-2023, 11:02 AM   #6
Weekend Racer
You have PM
Old 12-16-2023, 11:19 AM   #7
Rick J
You have PM
Replied
Old 12-21-2023, 10:14 AM   #8
Matt@PAC
Liked 24 Times in 4 Posts
Thank You!
Feel free to share specs or call in for a recommendation.
866-799-9417 or 248-621-0480
Matt@PAC is offline   Reply With Quote
Old 12-21-2023, 10:22 AM   #9
Liked 10,691 Times in 2,227 Posts
^^^^^^^^^^^^ Matt is always very helpful!
