Old 12-09-2023, 06:24 PM   #1
chopperloco
chopperloco's Avatar
Liked 82 Times in 23 Posts
Default Looking for info on this trans. Dynamic
Seems to be a Mopar trans to Chevrolet bell housing
Has not been used
Want to list it for sale once i have more info on it
Thanks
Dom
chopperloco is offline   Reply With Quote
Old 12-10-2023, 10:24 AM   #2
Steve Grady
Steve Grady's Avatar
Liked 63 Times in 32 Posts
Default Re: Looking for info on this trans. Dynamic
Is the bellhousing a cast part of the case, or does it bolt on? Hard to tell from your pictures.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 12-10-2023, 10:44 AM   #3
rsalemi
Liked 21 Times in 9 Posts
That is a 904 Chrysler built for AMC . It was used in AMC cars in early 80's in Sprite and others with the GMC 4 cyl Iron Duke motors . They had a lower first and second gearset - 2.72 and 1.54 instead of the 2.45 1.45 standard gears. As far as I know, everything is standard 904 internals. AMC also used the 904 with AMC bolt pattern behind the 6 cyl 258 motor. That's what I use behind the 4.0 in my Comanche. That trans will probably need the MOPAR converter.
rsalemi is offline   Reply With Quote
Old 12-11-2023, 09:04 AM   #4
chopperloco
Bolted
Old 12-11-2023, 03:26 PM   #5
Liked 5,072 Times in 1,933 Posts
Don't know about this one either..
In 1980, the Iron Duke was redesigned with the new GM FWD bell pattern.
The one pictured is a std Chevy RWD pattern.
Old 12-11-2023, 09:25 PM   #6
jmantle
Liked 169 Times in 80 Posts
AMC 904 postal van transmission. I believe they were all 904's, not the 998/999 V8 version which had a larger front servo and 4 pinion planetaries. Easy to tell a V8 unit from the outside, they have 2 ribs on top of the rear servo.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 12-12-2023, 03:13 PM   #7
chopperloco
Is anyone familiar with the Dynamic that built this trans.?
Are they still in business?
Thanks
Dom
Old 12-12-2023, 04:24 PM   #8
65signet
Liked 44 Times in 21 Posts
https://www.dynamicconverters.com/converters.htm
Steven Barnes
Stock 704 N/SA
65signet is online now   Reply With Quote
Old 12-13-2023, 09:58 AM   #9
pmrphil
Liked 345 Times in 149 Posts
Dynamic transmissions is in Connecticut, used to be partners with Frank Lupo's Dynamic Converter, but I don't recall what year they split up.
Phil Molski
PMR Performance
S/C 1623
Old 12-13-2023, 02:43 PM   #10
340Cuda
Liked 756 Times in 328 Posts
Dynamic Transmissions has an active Facebook page, they have a website but it seems to be broke.
From Facebook:
104-5 Enterprise Dr # 5, North Branford, CT
(203) 315-0138
dynamicracemail@aol.com
