Liked 554 Times in 156 Posts
1974 Corvette 454/270 HP intake manifold 336789 casting number
$125 BBC Oval Port 049 heads bare 1970-73 402 & 454 Heads 113 CC $300 Mid Year Corvette Big Block Oil Pan notched to clear 67-69 Camaro steering linkage with windage tray $300 Mid Year Corvette Small Block oil pan $250 Porta a Tree Full Size Practice tree and Eliminator with foot pedal and 2 hand buttons. half LED bulbs half incandescent $900 Holley 3916 3 barrel vacuum secondary gone through $750 Holley Davinci 750 dbl pumper $500 Holley BG 750 Dble Pumper $600 Holley 3310 from a 1965 396/425HP 780 cfm carb dog leg boosters 4 corner idle screws and 2 metering plates, complete $500 sbc 1971 350 intake manifold #39973488 $85 Aerosonic aircraft altimeter $150 PG deep aluminum TCI trans pan with cooling fins and filter spacer powder coated silver $125 Mezziere safety cap 16lb radiator cap $75 PG removable grab handle polished $50 Hardened PG turbo input shaft 1.82 $100 Biondo Starting Line enhancer/throttle stop air solenoid $100 for pics contact Rich 631-461-6761 Last edited by rboyle; 10-19-2023 at 06:21 PM. |
