Old 10-09-2023, 02:16 PM   #1
Doug Domm
Liked 84 Times in 21 Posts
Default Front end ride height change and effect of alignment
How much effective change to alignment is there when changing ride height. More specifically on first gen f body when raising ride height how does that change camber? Will it create more negative camber or will it create more positive camber? Also what direction will the caster go, towards positive or negative?
Doug Domm is offline   Reply With Quote
Old 10-09-2023, 04:52 PM   #2
Billy Nees
Liked 7,754 Times in 1,741 Posts
Default Re: Front end ride height change and effect of alignment
Raising the ride height on an early Camaro will make the camber go negative.
Depending on how much you are raising it, it may not be an issue.
Billy Nees 1188 STK, SS
