Old 09-21-2023, 01:26 PM   #1
CraigG
Liked 3 Times in 2 Posts
Default Positive Rake Angle/Ride Height on Small Tire Ladder bar
Hey Everybody,
I have a 4 degree positive rake angle on the ride height and wanted opinions .
Thanks, Craig
Still launching at 4,500 - 2-step with 5,000 still to grab.
Turbo 400 4.11 Pro gears with MT 10.5w x 28 slicks
Front suspension:
Comp Engineering single adjustable
Adjusted to 90/10 settings
5 x 18 #180 springs
Low friction control arm bushings and ball joints
Front end limiters set to no limiting
Total Race Weight 3440
Front weight 1860
Rear weight 1580
Percentage Basis Front to rear 55% to 45%
Rear suspension:
Full length Competition engineering adjustable ladder bars
Bottom hole lowest front heim end setting
Right bar - slight preload
“5 #150 lbs - springs with spring jacks
Comp Engineering Double Adjustables
Pinion angle 2 degrees negative
MT 10.5w x 28 slicks with tubes at 14 pds cold - best runs
Thanks Guys, Craig
CraigG is offline   Reply With Quote
Old 09-21-2023, 01:55 PM   #2
Jeff Stout
Liked 665 Times in 262 Posts
Default Re: Positive Rake Angle/Ride Height on Small Tire Ladder bar
I might be all wrong but thats a large percentage on front. I would think getting the ladder bar to be up hill as to separate rear end from body. Need to get tire planted and let rear shock control separation. Im guessing 53% or less up front. If this is for no prep then the starting line ratio is to much.
Jeff Stout is online now   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
