09-07-2023, 01:22 AM | #1 |
Liked 83 Times in 20 Posts
Dish soap coating
Long ago I had a pair of MT slicks that would loose air through the sidewalls, you could watch the bubbles form. It had been suggested to try coating the inside with liquid dish soap and it worked. Is this still somewhat a common practice or more so with MT?
09-07-2023, 06:51 AM | #2 |
Liked 236 Times in 124 Posts
Re: Dish soap coating
This is one of those things that you'll get multiple different opinions on.
I do it on any drag tires I mount tubeless. Plain blue Dawn. I pour it in and use a cheap paint brush to apply. |
09-07-2023, 08:10 AM | #3 |
Liked 1,656 Times in 507 Posts
I run Hoosier tires and have never had issues with the tires loosing air. I have heard of people using the dish soap method but I have never had to do that.
Mike Pearson 2485 SS |
09-07-2023, 09:01 AM | #4 |
Liked 228 Times in 120 Posts
I have a pair of M/T ET streets that always went flat sitting just a short time. My problem was more about air leaking around the rim screws, but I put "Slime" tire sealant in them and they've only lost 3 lbs. since May. (Just sitting in the garage, on the car.) I wiped it around inside and concentrated on the beads.
09-08-2023, 03:31 PM | #5 |
Liked 309 Times in 80 Posts
The 1st pair of MT I had were soaped up and leaked. The new pair went on dry and they hold air
09-08-2023, 05:07 PM | #6 |
Liked 17 Times in 8 Posts
Soaping the tires is worth it just to make it smell better when airing the tires down.
FB/Et/Index Racer Mark Mueller Can't afford Class Racing. You all crazy! |
09-08-2023, 10:01 PM | #7 |
Liked 4 Times in 4 Posts
We've always soaped our MT's. Hoosiers and Goodyears have never needed it.
