Old 12-29-2007, 10:12 PM   #1
SlickVic
SlickVic's Avatar
Default Powerglide V8 Gear set
Was given a powerglide that has been sitting around. Needed just the case but decided to open up just for grins and smiles. Found a stock v8 gear set which is all i run anyway. problem is that the trans must have sat outside for sometime, about half of the gear set is rusted. I can't get it to spin. Is there anyway to clean this such as glass bead or acid dip or something that won't destroy it?? Thanks for the info.
87 Cavalier, 92 Corvette, 72 Nova, 68 Firebird
SlickVic is offline   Reply With Quote
Old 12-29-2007, 11:42 PM   #2
Mike Hedger
Default Re: Powerglide V8 Gear set
I would try to bead blast it first with about 90 PSI and stay back from it about 6" to try and dust off the rust. I might have a stock set of 1.76 gears and pins if you need them let me know, Mike
Mike Hedger S/C 4646
MPH Racing and Fabrication
Mike Hedger is offline   Reply With Quote
