Old 07-11-2023, 05:33 PM   #1
tolaas
Default Master cylinder
I have Strange duel calipers at the rear and Mark Wiliams single calipers at front, have strange mastercylinder 1,125, is it to small master cylinder? I think i have long way for the pedal.
Thanks, Torbjorn
tolaas is offline   Reply With Quote
Old 07-12-2023, 03:43 PM   #2
340Cuda
Liked 805 Times in 341 Posts
Default Re: Master cylinder
My car has Strange duel calipers in back Strange singles in front. I have a Strange master cylinder but I don't remember what size. No problems but I do run 2 PSI residual valves front and rear and that helps me keep a good pedal.
All hard lines except for -3 from the frame to the wheels.
However I may be causing some brake drag with those valves, don't know.
Old 07-12-2023, 08:47 PM   #3
SDT1DYI
Liked 456 Times in 148 Posts
Dual rear Calipers require larger volume than a single fronts. I would call both Strange and M W and confirm piston volumes. Ask Strange which port , front or back has more volume output and tube it accordingly. Based on the Piston areas , Strange should tell you if MS bore size has enough volume.
Steve Teeter Stk/SS 620
SDT1DYI is offline   Reply With Quote
Old 07-13-2023, 08:17 AM   #4
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
If interested
Have a New WIldwood Master Cylinder for sale.
Dan
Old 07-14-2023, 10:39 PM   #5
CMcAllister
Liked 930 Times in 264 Posts
Port towards the pushrod goes to the side needing more volume. In this case, the rear.
