Old 07-07-2023, 10:34 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default fbody frame connectors
95 camaro stocker, wish to build a through floor set, 2''x 3''sq tubing... what thickness is required? any building proceedure or suggestions ? tks
Old 07-07-2023, 11:56 PM   #2
SSDiv6
Default Re: fbody frame connectors
Get the weld-in subframe connectors from Spohn or Southside Machine.
Old 07-09-2023, 10:20 AM   #3
Charles Stewart
Liked 755 Times in 213 Posts
Section 11A,page 9 Stock car in FRAME paragraph:
https://www.nhraracer.com/Files/Tech...k_23_04_05.pdf
Charles Stewart is offline   Reply With Quote
Old 07-10-2023, 11:36 AM   #4
CMcAllister
Liked 920 Times in 259 Posts
Common sizes available are .125" and .083" wall.
The .125 is more common. It's also heavy as crap. Use .083. Chassis places and suppliers likely to have it.
Through the floor, and welded, will be more substantial in stiffening the car. Adding "outriggers" to the rockers provides even more rigidity and gives a location for the main hoop to be welded in with out using plates.
It's also more work.
Old 07-10-2023, 03:53 PM   #5
richie 2
allstar perf has the .083" in 4' or 7' length.
