Old 06-27-2023, 10:46 AM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default TH 350 case
Driveshaft broke and took case with it. I’m told the 4WD cases are stronger. Are 2WD and 4WD cases interchangeable? How can you tell the difference? Basically I’m wanting to find a case and hopefully it didn’t damage too much inside. So internals can just be swapped. And I can keep it as a spare
Old 06-27-2023, 11:29 AM   #2
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Default Re: TH 350 case
I figured it took the case out also. YEARS ago at the IHRA points race in Norwalk my C4 bound up and took the top of the case off.. Good times
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 06-27-2023, 11:35 AM   #3
Jim Kaekel
Liked 535 Times in 110 Posts
The 4WD case accepts a cast aluminum dust cover and is a bit stronger in that area but the bellhousing area isn't much stronger. Any time you lose a driveshaft, you can almost guarantee the case is going to be cracked. Stronger alternative is a JW or ATI bellhousing, or ATI case with bellhousing. Internally as long as it's an early, non lock-up TH-350 and not a TH-250, which includes an external adjuster for an intermediate band, cases and internal parts are fully interchangeable. Also 6", 9", or 12" tailhousings with the appropriate output shaft.
Jim Kaekel 3836 STK
