Old 05-22-2023, 03:39 PM   #1
3 window
Liked 3 Times in 2 Posts
Default 12 bolt pinion shim
To all, anyone have a good guess at a pinion shim for an oem 3.31 gear in a 12 bolt? There’s nothing scribed on the head of the pinion or ring gear. I could be wrong, but I feel like there had to be a quick reference when gm was setting up hundreds of rear ends a year back in the day. Any help is much appreciated. (NOTE: I did find documentation that said 12 bolts got a .030 shim).
3 window is offline   Reply With Quote
Old 05-22-2023, 04:27 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Default Re: 12 bolt pinion shim
Yes start with .030 shim, set backlash, check the pattern
Old 05-22-2023, 04:31 PM   #3
3 window
Will do. Thanks Glenn
Old 05-24-2023, 09:53 AM   #4
prostockpete1
Liked 90 Times in 52 Posts
Back in the 60.s I did lots of GM muscle cars with 12 bolts & typical shims from .028 to .032 ..start with the .28 & old trick to prevent bearing from getting wrecked on & off many times to change shim is to heat the bearing up to expand so it slips on & off off easy
prostockpete1 is offline   Reply With Quote
Old 05-28-2023, 08:58 AM   #5
Chevy55
Banned
Liked 179 Times in 89 Posts
I use the reference when I'm having a problem setting up a ring and pinion or I do not have access to the original shim or the old gear was not set up correctly.
GM .035
FORD 8"-9" *020
FORD 8.8"-7.5" .030
ALL DANA'S .035
8 3/4 X 1 3/4 PIN .090
8 3/4 X 1 7/8 PIN .020
MOPAR 9 1/4 .020
Chevy55 is offline   Reply With Quote
Old 05-28-2023, 09:43 PM   #6
Liked 5,147 Times in 1,964 Posts
12 bolts usually take the following, in my experience:
2, 3 ratios...mid to high .020's
4, 5, 6 ratios...low to mid .030's
Old 05-30-2023, 01:17 PM   #7
Dirk Olson
Liked 172 Times in 46 Posts
.026 to .028 will get you close. Remember when setting a used gear set that it is highly possible that you will not see a good pattern. you can get close adjust backlash a little on the loose side monitor noise on coast adjust if necessary.
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 05-30-2023, 05:54 PM   #8
Alan Nyhus
Liked 800 Times in 237 Posts
Doing a new set, .030-.032 is my default. On a used set, I'll hedge thinner by a couple thou. and pay more attention to the coast side. A bit of red Loctite on the pinion shaft where the front bearing registers and eliminate the crush sleeve.
"That'll never work....."
Old 05-31-2023, 09:04 PM   #9
3 window
Thanks everyone. We’re on the right track for sure. I set it up with a .030 and based on the master housing depth of 4.670, it’s dead nuts on (pinion depth of 2.755 plus the thickness of the pinion head 1.915 equals 4.670).
Old 06-01-2023, 06:46 AM   #10
Glenn Briglio
That's fine but pattern and backlash are what matter.
