Old 04-24-2023, 02:31 PM   #1
Rich osmond
Default Tire Help for Heads-up Manual Transmission Class
I am building a car for the NMCA Coyote stock class (sealed factory engine ~500HP, 3000# min weight, and g101a transmission). The cars 60' in the mid-1.30 range, and run ~9.7's. Nearly all of the cars in the class run 26" x 10" M/T stiff all slicks, but I am wondering if there is any advantage (or disadvantage) to running a 28" tire with the appropriate gearing. Any experience is appreciated!
Rich osmond is offline   Reply With Quote
Old 04-24-2023, 02:57 PM   #2
Ralph A Powell
Liked 226 Times in 137 Posts
Default Re: Tire Help for Heads-up Manual Transmission Class
What clutch and flywheel (steel or aluminum) and what 1st & 2nd gear ratio? A larger diameter will give you more contact area
Old 04-24-2023, 03:19 PM   #3
Rich osmond
Thanks. Aluminum flywheel, single clutch disc 10” min, but we can run a tamer. First gear ~ 3:1, second gear ~2:1. Appreciate the help.
Old 04-24-2023, 05:34 PM   #4
Jim Caughlin
Liked 806 Times in 246 Posts
Oh boy, here we go again...
Jim Caughlin is offline   Reply With Quote
Old 04-24-2023, 05:38 PM   #5
Rich osmond
OK. I’m just seeking a little help. Thx
Old 04-24-2023, 10:06 PM   #6
1347
1347's Avatar
Liked 1,031 Times in 283 Posts
why wouldn't you put a 30x9 bias tire the Stick stocker guys run? i know thats why you are asking what to use, but I would think a 30x9 would give a much better contact patch over a 26x10.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 04-24-2023, 10:17 PM   #7
Stephen & Horace Johnson
Liked 165 Times in 54 Posts
28s are the biggest they can run
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 04-25-2023, 01:20 PM   #8
James Hensler
James Hensler's Avatar
Liked 58 Times in 36 Posts
I used to run the 28x10.5 Stiff in Renegade. Back then we had to weigh 3000 and made more HP 850 but with a single disk Ram and a adjustable pressure plate I 60 footed 1.25 and ran 9.0’s a DOHC 4.6
I know this isn’t your combo but it’s about as close as you’re going to get here!
SS/AH
328X
James Hensler is offline   Reply With Quote
Old 04-25-2023, 01:37 PM   #9
Rich osmond
Thank you, James. This is very helpful and something I will consider. As you know, I will need to balance clutch slip, wheel speed, and rotating weight, so I will probably need to test with a short tire/gear package, vs a tall one. Thanks again.
Old 04-25-2023, 04:50 PM   #10
Jim Caughlin
Stick to basic 'meat and potatoes' components that have been working for Stock class cars for years, Soft Lock, alum flywheel, G101 and the 10 x 28 should be plenty of tire to get you well into the 9 second range. Run the clutch as loose as you can get ways with and oh yeah, don't use the clutch to shift.
