Liked 1,466 Times in 548 Posts
This posting is to allow some rational and logical discussion on the use of, and the market availability of aluminum aftermarket cylinder heads for the Super Stock class. I would also like to ask to please refrain the personal attacks and non-sense arguments in the discussion.
On this subject, I do not have a vested interest either. I have been asked by several race engine builders and cylinder head shops to assist them in getting an aftermarket aluminum cylinder head approved by NHRA for Super Stock class use only! As we all are aware, NHRA has approved several makes of both cast iron and aluminum for use in the classes. However, with the acquisition of aftermarket and racing product companies by conglomerates, they have changed the business model from hard-core racing to bringing out products for late-model vehicles only. Edelbrock was for some time, the main supplier of cylinder heads and intake manifolds for the class. Another example is the Edelbrock SBC Victor “E” intake manifold which has been discontinued also. However, after being acquired by a group of investors, the bean counters changed the business model, with emphasis on the Chevy LS/LT, Ford Coyote, and Mopar Hemi platforms. I confirmed this at last year’s PRI Show in a conversation with Edelbrock’s Program Manager Director for the cylinder head product line. Nevertheless, every time someone calls the NHRA Glendora office, they hear the same story…Edelbrock will have cylinder heads available next month and has been stating the same narrative since last year. The truth is that my job requires me to travel to Olive Branch, Mississippi twice a month and my employer owns a distribution center a few miles away from Edelbrock. Each and every time I stop to ask about their status, they do not have an idea because it is not in their schedule. When I confronted Glendora on the subject, they did not have an answer. Last year I submitted several aluminum cylinder head options from various manufacturers that could have easily met the requirements for a Super Stock cylinder head and all were rejected for one reason or another. The rationalizing for the rejection from a technical standpoint did not make sense either. Their narrative did not even concur with what they believed they had approved. As an example, they claimed the Edelbrock SBC-approved cylinder head casting has a 170cc intake volume when in reality, it is 180cc. Moreover, the Performer RPM casting that the cylinder head casting is based on, the intake to exhaust valve centerline spacing is wider and does not match the OEM spacing. The reason for the wider spacing is for allowing bigger valves. As a matter of fact, when you order custom pistons for your Super Stock SBC, make sure to let them know you are using the Edelbrock cylinder heads so they can machine the valve notches to the proper location. My last effort was to submit the SBC Profiler 176-X-CORE, Porter's cylinder head casting for approval. Technically, this would have been an ideal cylinder head casting for Chevy Small Block racers due to the fact the ports are small, allowing the development of an intake or exhaust port that would not require welding and/or epoxy. Also, no pushrod holes and the valve seat and throat are small enough that would not require welding for the installation of small seats for smaller valves. The cylinder head also has the OEM intake to exhaust valve centerline spacing. The elimination of extensive welding of the cylinder head, having the welded casting treated, and not worrying about distortion, is also a money saver. The casting price is also way lower than the Edelbrock, available and made in the USA. After much effort, including submitting technical data and a sample of the cylinder head, NHRA also rejected the Profiler cylinder head. They also said that SRAC also rejected the cylinder head, which I would like to know in this open forum if they did or not, and their reasoning. For those that may say that this would have been only good for the Chevy racers if this cylinder head casting would have been approved, Profiler would have been eager to have castings also available for other engine makes also. Having a “Porter’s” casting is cost-effective for a manufacturer since they do not need to install seats, guides, or drill pushrod holes. This said, the parts availability issue is worrisome and will get worse. Either NHRA wants racers to build late-model cars or electric cars, or the class to disappear. |
#2 | |
Liked 186 Times in 63 Posts
Liked 899 Times in 326 Posts
I went through this. Dave Layer and I researched several heads to a replacement of the famous water leakers of the 083 SBC. They are still impossible to find as the 87-92 IROC and Formula engines they came on are not normally separated from the short block at the junkers/rebuilders. It's too valuable a combo for Rodders and Street Enthusiast. The moral of the story back then was if you owned a 350 cu in 87-92 Camaro/Firebird Iroc or Formula and wanted to run Superstock (and not GT) go buy another car. No heads were available, and if you're lucky to find a set,,,,their junk. So we looked at some GM aftermarket castings.... Dart, World's, even Brodex. The 170cc Dart Super Stock castings was a replacement head made for replacing a head on a street driven L-98. so we went with them.Dave was sending letters to Bruce and I had everybody I know writing letters asking/pleading for this head.Bruce was showing some interest so I drove a new 170 cc Dart 070 casting example (stock,non machined) over to Indianapolis for him to evaluate. BTW, Aluminum was out of the question. Just too many folks pushing back on that. We ending up getting approval and I believe like you it was to be a Superstock only option. Dave had a couple other customers in line to get them so I did not get in on the first batch. He made four sets and almost instantly 3 of them leaked. Heck they were as bad as the 083's.I remember the day when Dave had to call Bruce and tell him the results. Bruce was kind of "having enough of it" and ask Dave "Just exactly what are you suggesting". so the process started again . The second set, the 180cc Dart 010 Iron Eagle head that everybody uses in the cast iron version of the L-98 was the second attempt. The first set is still in the guide, but no one use these things in SS. Just too thin. Now we can't get the 010 Darts either! Good Luck, Our ace in the hole and very knowledgeable Bruce retired many moons ago.
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 04-15-2023 at 04:39 PM. |
#4 | |
As always, you are clueless and just posting to stir the pot with no facts. Just go to your basement to your keyboard jockey role! |
#5 | |
The proposed Profiler casting also allows for both center or perimeter valve covers if NHRA wants the visuals. |
#6 | |
Liked 36 Times in 17 Posts
So let me get this straight... All the work you have to do to the OEM casting, brazing, seats, guides, epoxy, is cheaper than a core that doesn't require that? Not only that it's not IF, but WHEN they crack...
And to be honest, the Edelbrock requires the same amount of labor. They need LOTS of work. |
#8 | |
If you can find a set of Edelbrock P/N 60887 or 60637 cylinder heads, post the links or where to get them. I know of a well-known engine builder that has 30 Edelbrock castings on order for over a year. Not wasting any more of my time responding to your dumb and idiotic comments. |
#9 | |
Liked 111 Times in 28 Posts
Man, I remember when it was straight up mansville to use your real name, along with a good argument...
Please be more like the great engine builders of class racer, like Westcott and a few others that don't use hidden names. I have no idea who the 2 main posters here are? SSdiv6 is unknown after what... 40 years? Bubski is likely a Ford guy of sorts, from what I can tell? You both make fun points at times, but really, man up and use your name, when asking for rules changes, so we can see your personal agenda. As for heads, race modified if you want fresh meat heads. Pretty sure its near billet over there? Many thanks to Jeff N. for spilling his guts, on what that leaky combo he ran was like, but you said it best, they leak. I haven't entered a race in 20 years now, and its stay and puke cash, or get a hobby that doesn't need revised every week! ex SSdiv5 Don Last edited by Don Sofranko; 04-16-2023 at 01:15 AM. |
