Old 12-22-2007, 10:13 PM   #1
Uncrated
Banned
Default MSD Digital ignitions
For "many years" [grin] I have used the MSD 6 AL or MSD 7 AL controllers.
In an effort to become more "modern" I am considering trying a digital controller.
Let me here about your experience/comments.
Thanks
Larry Woodfin
Uncrated is offline   Reply With Quote
Old 12-23-2007, 02:01 AM   #2
Sean Kennedy
Sean Kennedy's Avatar
Send a message via AIM to Sean Kennedy
Default Re: MSD Digital ignitions
I am also interested in this.
I have been told that the 2-step is a more gentle due on the bottom end. Due to being less random.
I have also been told that the RPM fluctuation on the 2-step is a lot smaller than the traditional box.
Anyone?
Sean Kennedy is offline   Reply With Quote
Old 12-23-2007, 02:16 AM   #3
Todd Hoven
Guest
Posts: n/a
Three years ago, I switched from a 6T box to a digital 6 box. Two step rpm is very consistant. Never had any problems with it. The biggest thing I liked about it was it has a adjustable timing retard built into it and a two step as well. No extra modules to plug in or wire. Very clean instalation. Just my 2 cents...
Old 12-23-2007, 06:59 PM   #4
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Digital 6 is an awesome box, due to the fact that it has nearly everything you will ever need in the one, small neat package.
Old 12-23-2007, 08:28 PM   #5
Mike Hedger
If you buy one spend the extra and get the Digital 7 it has quite a bit more in it than the 6. They are a great peice but remember to get the correct coil with it they don't recomend using the pro power from the old 7AL setup. No more RPM modules to keep up with either.
Have a Merry Christmas, Mike
Mike Hedger S/C 4646
MPH Racing and Fabrication
Mike Hedger is offline   Reply With Quote
Old 12-24-2007, 01:42 PM   #6
Bryan Broaddus
Liked 18 Times in 4 Posts
If you have a 6AL or 7AL2 then you can get all of the advanced functions buy purchasing an MSD 8979. This is a fully digital controller that will do everything a Digital 7 does but is only about $450.00. It is used in conjunction with you existing 6 or 7 box (connects at the points and two step plugs in). It runs on the same MSD software as the Digital boxes. It has individual cylinder timing, starting line retard, timing curve, retard for each gear, rev limiters, programable shift light output (which I use to run my auto shifter) and more.
I have been using one for several years with great results. MSD and the aftermarket does not push this box because they want to sell you a new $1100 Digital 7. When I questioned them about this box at the MSD trailer they wanted to know where I found out about this unit. Most of us have a spare 7AL so if you have a failure it means you only have to replace have the system for half the cost. As a matter of fact I priced the 8979 and a new 7AL2 and it was less than the Digital 7. Seems like a better deal for my money!
Bryan Broaddus 7568 STK ,SS
Bryan Broaddus is offline   Reply With Quote
Old 12-24-2007, 02:16 PM   #7
Jared Jordan
Liked 547 Times in 121 Posts
Send a message via AIM to Jared Jordan
We've had a very positive experience with the Digital 7 box (both PN# 7530 and 7530T). Everything you need is in one unit so the installation looks a lot cleaner, the software is easy to use, and we've only had one box go bad in 7 years of using them.
Brian: do you use the PN# 8979 you were referring to in your post? The Belvedere has a 7-AL2 on it and I was thinking about getting one of the digital controllers rather than ripping out the whole ignition setup in the car and putting a Digital 7 in it.
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 12-24-2007, 02:29 PM   #8
Bryan Broaddus
Jared,
Yes, I use one in the Monte Carlo. It has worked great for me. You can install it in a few minutes too. You have to add the inductive pickup on the #1 pulg wire for the individual cylinder timing but that is all. Runs on the same software as the Digital 7. The MSD software will run all on them. It automatically identifies which box is connected on power up.
Old 09-01-2008, 11:08 PM   #9
69Cobra
Liked 2 Times in 2 Posts
so is the 7531 legal in stock?
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 09-04-2008, 12:03 AM   #10
sixty8
sixty8's Avatar
General Reg 8:3 says that the 7531 and the 7561 are prohibited in NHRA competition.
sixty8 is offline   Reply With Quote
