Old 03-11-2023, 09:00 AM   #1
James Hensler
James Hensler's Avatar
Liked 58 Times in 36 Posts
Default 60mm Cam Plug Question
Are you guys making or buying a 60mm cam plug? I see Brad Anderson makes one with an O-Ring. So how is everyone doing it?
SS/AH
328X
James Hensler is offline   Reply With Quote
Old 03-12-2023, 11:41 AM   #2
Todd Gross
Liked 54 Times in 24 Posts
Default Re: 60mm Cam Plug Question
When replacements are not readily avaiable, I have made replacement plugs by buying aluminum disc from McMaster, center drilling them to put a temp bolt to chuck in lathe to turn to size, add oring groove then tap the temp bolt hole for an allen pipe plug.
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
