Liked 115 Times in 35 Posts
Which port should go to the front brakes on the mopar/chrysler aluminum master cylinder?
I have seen this master on many cars and plumbed both ways. Mine is front port to front brakes. Correct? |
Liked 91 Times in 51 Posts
That is how mine is plumbed.
Liked 346 Times in 126 Posts
do you use the one with the largest brake fluid capacity?
Liked 1,874 Times in 576 Posts
The larger Reservoir goes to the brakes that hold the most amount of fluid
Liked 858 Times in 234 Posts
Per the instructions for a Strange Mopar style master cylinder. The reservoirs are the same size front and rear, however the piston volume is larger on from the port closest to the pushrod.
■ The outlet port nearest the pushrod supplies the most fluid volume and should be plumbed to the calipers requiring the most volume. Typically a drag race only car will have the largest calipers on the rear, while a street driven car will have the largest calipers on the front. Attach lines accordingly Since most S/SS cars have the same calipers front and rear it really does not matter although I always plumb the larger section[ closer to the pushrod] to the rear brakes.
#6 | |
Liked 800 Times in 244 Posts
#7 | |
Liked 913 Times in 256 Posts
And make sure there some sort of retainer, besides the rubber ring, to positively keep the pushrod in the MC. |
