Old 02-26-2023, 10:26 AM   #1
scott gray
Liked 27 Times in 4 Posts
Default LT-1 valve guides
Quick question for you LT-1 guys . Got a set of heads for a racer and they have stock guides in them with proper clearances . This is a SS application and he insists he wants new guides . The heads are like new . Is it worth it to change the guides or just leave them be ? Thanks in advance .
scott gray is offline   Reply With Quote
Old 02-26-2023, 06:33 PM   #2
richie 2
Liked 205 Times in 93 Posts
Default Re: LT-1 valve guides
i would leave them alone.
Old 02-26-2023, 07:49 PM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
If they are good now ,they probably won't be long after SS use...
they don't need 11/32 valves in SS either... 5/16 or 8MM will be lighter and a little more air... liners to reduce or I prefer replacing with bronze guide,less chance for a problem..... I would check with SI valves they have a lot of bronze guides nobody else has....
Mike Taylor3601
Old 02-27-2023, 10:19 AM   #4
Hacksaw
Liked 314 Times in 177 Posts
Never thougt it was legal to change valve stem diameter or have I missed a rule change?
