Old 02-12-2023, 07:35 PM   #1
mike britt
Liked 62 Times in 30 Posts
Default MSD Ignition box
Can you get away with running a 6AL or do you have to have a 7AL. This is a 350 TPI 245/281 combo. Any advise would be appreciated.
mike britt is offline   Reply With Quote
Old 02-12-2023, 11:32 PM   #2
Rory McNeil
Liked 1,074 Times in 294 Posts
Default Re: MSD Ignition box
I have had the same MSD 6T ignition box in my low 10-high 9 second bracket car for over 30 years, with zero issues. And I used a MSD 6AL in my 85 Mustang Stocker, but have never used a 7 series box, so I can`t say if a 7AL may potentially be any better. Certainly didn`t notice any downfalls with the 6 series.
NHRA 6390 STK
M/S 85 Mustang
Old 02-13-2023, 08:10 AM   #3
427FE
427FE's Avatar
Liked 347 Times in 79 Posts
Do you have it already?
Pat Clemente
#1427 B/S
427FE is offline   Reply With Quote
Old 02-13-2023, 09:26 AM   #4
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: MSD Ignition box
Good morning to all,
Yes you can certainly use an MSD 6AL box, the 7AL " might " be slightly better in overall performance, but the 6 box will work. Over the years I've found the 6 series boxes to be the most reliable. That's what I've found, good luck with your racing season.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 02-13-2023, 09:36 AM   #5
Craig Porter
Liked 97 Times in 25 Posts
I bought a bracket car from a friend of mine two years ago and it had a digital 6 plus in it and worked great . I completely rewired the car last year and put a 7 AL box in it that I had and it didn’t run any different .
Craig Porter is offline   Reply With Quote
Old 02-13-2023, 09:41 AM   #6
4543
Liked 634 Times in 139 Posts
Mike I have a Digital 6 in the Corvette. Works fine. How’s the car doing? Mike McMahan
4543 is offline   Reply With Quote
Old 02-13-2023, 09:44 AM   #7
mike britt
I have a 7 AL2 in it now but I am going to replace it because I think it has a problem. At 6300 it acts like it's on a rev limiter and I allready replaced the distributer and wires so it's next.
Old 02-13-2023, 10:06 AM   #8
PozQB14
Liked 42 Times in 17 Posts
Hey Mike, what kind of shifter do you have? A few years ago, I had a similiar problem and it was my turbo action line lock button that wasn't fully disengaging. I had to push on the wires to ensure the little red button was fully out.
PozQB14 is offline   Reply With Quote
Old 02-13-2023, 02:05 PM   #9
M120
Liked 22 Times in 12 Posts
Question Re: MSD Ignition box
I replaced a 7AL2 with a 6AL between rounds after having the car shutdown on return road. Before it shut off the tach was jumping all over the place and would barely run.
I was racing an index class using weight to run the index. I didn't change weight after replacing with 6AL and ran exactly the same ET.
This was with a ZZ4 engine making around 380 hp . 11 second Chevelle
M120 is offline   Reply With Quote
Old 02-14-2023, 04:48 AM   #10
Adger Smith
Liked 880 Times in 311 Posts
Make sure your coil matches the box you are using.
Chart:
https://www.holley.com/brands/msd/pr...gnition_coils/
There is also a difference in some of the distributor pick ups and boxes.
I think it is analog vs digital. ran into a couple of customers with match up issues a few years ago.
Make sure they are compatible.
Adger Smith (Former SS)
