Old 01-27-2023, 10:25 PM   #1
Tom Meyer
Liked 354 Times in 120 Posts
Default Mallory distributor cap rotor needed
I'm looking for a new cap and rotor for my old mallory tach drive distributor. Any info and part numbers would be appreciated. Thanks Tom
ID:	65827   Click image for larger version
Tom Meyer 5240 SS Stock ???
Old 01-28-2023, 12:01 AM   #2
Jim Hawkins
Liked 115 Times in 35 Posts
Default Re: Mallory distributor cap rotor needed
Tom, I used to run what I believe is the same dist. purchased about 1990. I did not have the adapter for the large cap with HEI terminals. The cap screwed down directly without the adapter and was smaller diameter with the old style push in terminals. At some point I could not locate a cap and rotor but somehow found that the cap for a 55-56 chevy without the window fit. That cap clipped on and would require holes drilled for the screws. I never did it but I think its the same cap otherwise.
Prob. not what you want but I thought I would offer what I found.
Jim Hawkins is offline   Reply With Quote
Old 01-28-2023, 02:33 AM   #3
B/S 428
Liked 154 Times in 34 Posts
Looks like a Mallory comp 9000, Ebay has new parts available. $39-$89 for a cap, $15 for a base. I run the same distributor on my comet 302. Brian Seaberg
B/S 428 is offline   Reply With Quote
Old 01-31-2023, 11:52 AM   #4
Leon Rennebaum
BS428 is correct:
The cap is a Mallory P/N 29745 as shown on the link: https://www.holley.com/products/igni...rs/parts/29745
Rotors, base, and wire retainer are listed under Service Parts. (select appropriate rotor according ot rotation/ distributor P/N).
Leon Rennebaum is offline   Reply With Quote
Old 01-31-2023, 06:20 PM   #5
Tom Meyer
Got some of the stuff ordered, the rotor was a different animal but moroso showed one to match. Trying to retain the original 11,000 moroso cable drive Tach that came with the car in 1983. This car was one of Garley Daniels C super mods from way back. Thanks for the help Tom
