Old 12-18-2007, 10:12 PM   #1
Bayou Shoe
Default Throttle stop racing first timer needs a little help
Getting ready for next season and I am debating weather to throttle stop the car all year or not with my new motor. I run allot of 1/8 mile mixed in with a little 1/4, I was thinking of just running the throttle stops all year so I could keep the same set up. 1/8 car runs 5.70's and I plan on running 10.90 index in 1/4 or 7.00 in 1/8. If the car runs a 5.70 what would be a good starting point for the timers on the stops, also how far out do you guys run before activating your stops, should i shift on time. Are most cars more consistent on throttle stops or should i just run it all out. I think I should run the stops because I will know my tune up is the same the whole year and adjusting stops would be easy. Give me a little input please it will be appreciated. Throttle stop is a dual baseplate Co2 system from Dedenbear with a CC3 controller.
Bayou Shoe is offline   Reply With Quote
