Planning on running my 66 coronet in stock and was wondering if anybody had a suggestion on tire size and wheel backspacing for the rear. any and all info is greatly appreciated
I have a 66 Coronet street car and the widest tire I can get on it is 9 inches. If you roll the wheel lip you will gain just about an inch. I think stock eliminator limits you to 10 inches any way.
The weird thing about my car and I have talked to others with 66-67 Coronets, is the tire clearance on the right side is less than on the left side. Obviously an engineering oops. I don't know if you are allowed to move the leaf springs inward in stock eliminator, but I think that would be the ticket to better clearance if allowed. |
Liked 772 Times in 192 Posts
The body mounts on those unibody cars are always so hard to loosen.
thanks for the suggestions guys much appreciated. if any one had a wheels size and offset suggestion that would be superb.
Liked 1,874 Times in 576 Posts
check out this link, it has pics of my street coronet with the biggest sizes you can use a lot of info on coronets on this site: scroll down to see my posts, keith944
http://www.dodgecoronet.com/forum/sh...?t=7808&page=3 |
Liked 14 Times in 11 Posts
Chrysler products have a unit body and the rear spring bolt to the unit body, A GM car of
that era had a full frame such as the 63 409 car. Now you may be able to relocate the rear axel spring pads enough to move it to the left, but that will then cause other problems.
Phil Saran Parker, Colorado |
Back to the orginal question, a 8 or 8-1/2 x 15 wheel with a 4-1/2 backspacing.
If Chad or Scott Loge see's this post maybe they will chime in, Chad runs a 70 GTX in stock.
Liked 6 Times in 2 Posts
For stock elim, a 66 Coronet should be the same as a 66 Ply Belvedere . The bigest you can fit is an 8" wheel with 4 1/2" back space . Tire size of 9 x 30 will just touch when turning corners, otherwise fine. Don't base measurements of 70 RR or GTX to relate to your 66 as they have bigger wheel wells. I have a 70 RR C/SA and can tell you they a lot bigger than your 66. John Lang
John Lang 365 STK, SS |
