Old 12-09-2022, 01:14 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Block Filler Necessary?
We had to source a new block since our GM casting 400 block bores are non repairable and the block is already 0.060 over. Went to a Dart Little M block with billet caps.
The GM block we had was filled to the water pump. Changing over to the Little M block is there enough rigidity in the Dart castings that filler is not needed or is it still good practice to fill the block?
Thanks,
Chad
Chad E532 is offline   Reply With Quote
Old 12-09-2022, 08:38 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
Default Re: Block Filler Necessary?
Thanks,
Chad
Sonic test the block will tell you what needs to be done.
