Old 12-04-2022, 12:57 PM   #1
Woodfin
Liked 225 Times in 90 Posts
Default electric vacuum pump
I hear talk about racers installing an electric vacuum pump. It seems to me, doing so is a good idea because it will remove moisture from the crankcase without the engine running. In my specific situation, it would be used with Methanol as a moisture remover, not a power enhancer.
Are any of you doing this?
Larry Woodfin
Old 12-05-2022, 10:11 PM   #2
Al Wilson
Liked 109 Times in 38 Posts
Default Re: electric vacuum pump
I installed an electric vaccum pump on my Nostalgia Super Stock car. My main reason for doing this was to minimize oil leaks...and it worked well for that. Here is an article with some info on the pump.
https://grannys.tripod.com/evac.html
My setup was much simpler, two hoses off the valve cover baffles, Moroso oil seperator, then to the vac pump.
Al Wilson
NSS 7160
W201 stock
Al Wilson is offline   Reply With Quote
Old 12-06-2022, 02:11 AM   #3
Woodfin
Thank you, I appreciate the information.
Old 04-30-2023, 03:05 PM   #4
Shaun Quill
Liked 105 Times in 26 Posts
Larry Woodfin
Did You have any luck trying this Larry? I was wondering how effective it would be at keeping the oil cleaner. Thanks
Old 10-06-2023, 11:19 PM   #5
Woodfin
Shaun, no, I have not done so yet, but I do think it is worth considering.
