Liked 13 Times in 6 Posts
I have a bracket car back half I need to up grade my driveshaft right now I have a 3" driveshaft spinning my motor about 8200 RPM . Was wondering before I order a better Driveshaft what size diameter can you fit in a stock tunnel Chevelle I'm asking here because I know some superstock cars buzz them motors pretty high Thanks
Liked 453 Times in 146 Posts
Call Jason at Mark Williams. They will build you a SFI certified driveshaft, based on you supplied car data.
Thanks , The question I should have asked was what's the fattest driveshaft you can fit in a stock floor I'm pretty sure I'm gonna need a 4" driveshaft . Has anyone put a 4" shaft in a stock Chevelle tunnel . Thanks again
Liked 79 Times in 28 Posts
I have run a MW 3" driveshaft in my superstock car too over 9000rpm with a stick shift. A 3.5" shaft would be more than enough and should clear with no issues.
Bruce Cameron 68 Nova 396 E/S 68 Camaro SS/? ex Checkmate Modified |
Liked 183 Times in 48 Posts
Driveshaft diameter comes down to critical speed based on RPM, material and length.
As someone else suggested, you may want to call Mark Williams. There are other vendors out there that are very good but I'm sold on MW parts. I have a MW 3.5" aluminum shaft in my super stocker turning 10,400 rpm. There's no vibration or anything that would suggest a problem. It gets hit pretty hard off the trans brake, too.
SS/BS 1921 |
Liked 890 Times in 248 Posts
Depending on how low the car sits, how high the pinion is, suspension travel and how the trans/engine is in the car, you can get into trouble on those with the height of the tunnel and crossmembers in the floor.
Thank you , I'll be calling Mark Williams
Liked 230 Times in 106 Posts
FYI. You can replace tunnel (make removable) in Super Stock but not in Stock.
Liked 54 Times in 27 Posts
I run a 4" MW aluminum driveshaft in an Olds F85. I cut the lede extensions off the seat belt bolts for more clearance, otherwise had good clearance.
