Old 11-05-2022, 09:35 PM   #1
mike britt
Liked 66 Times in 31 Posts
Default FAST XFI fuel table
When I view my fuel table it only goes to 91% throttle on top and 9% on the bottom. What setting am I missing? Above 91% is pretty important. Anybody have any ideas?
mike britt is offline   Reply With Quote
Old 11-05-2022, 11:59 PM   #2
Kdw1403
Liked 68 Times in 22 Posts
Default Re: FAST XFI fuel table
Go to your fuel table and Put you curser on the percentage you want to change. In your case 91%. Double tap and put in the number 100 then click ok. You can change all of them as well as the rpm the same way. At least that’s the way mine works. Hope this works. You might need to recalibrate your TPS also.
Kdw1403 is offline   Reply With Quote
Old 11-06-2022, 10:40 AM   #3
mike britt
I have calibrated the TPS and it starts at 0 and goes to 100. After I set the wide open to 100 and idle at 0 can I interpolate the rest of the numbers in between?
Old 11-08-2022, 09:30 PM   #4
Kdw1403
Yes.
Old 11-08-2022, 10:02 PM   #5
mike britt
That was an easy fix. Thanks.
