Old 12-10-2007, 12:40 AM   #1
Alan Warman
Default Question on gas mileage
Since it doesn't seem like the gas prices will be going down soon, I need to figure out a way to get better gas mileage. Our set up is an 03 Dodge Double-Cab Dooley with a Cummings and a six speed, all stock except K & N air filter, and synthetic oils. We tow a 24 foot enclosed trailer and we average about 12 - 14 mpg towing. Just wondering if anyone had any tips or tricks on how to get better gas mileage. I didn't know if it might be better to chip the vehicle or put a V-nose or a bubble on the trailer. Has anyone tried the wings on top of the cab of the truck?
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 12-10-2007, 12:45 AM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Re: Question on gas mileage
Alan I have an 03 2500 cummins 6 speed & I get the same mileage....but get 20 just driving to work.
Old 12-10-2007, 01:38 AM   #3
div 5
Default Re: Question on gas mileage
Mine does much better at 55 than it does at 70.
div 5 is offline   Reply With Quote
Old 12-10-2007, 01:55 AM   #4
Alan Warman
Out here in Tx I can get 24 empty,and if I am towing the open trailer I get 18-20.Mine gets the best mileage
at 62mph but it takes forever to get any were.Greg how do you like your new Olds,I nearly have mine up and running.
Alan Warman
STK 4107
Old 12-10-2007, 08:11 PM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Cool Re: Question on gas mileage
I have a Dodge 2004.5 Cummins Quad-Cab dually with an auto and 3.73 gears. It has a fiberglass topper that kicks up higher in the back and tows a 26' Pace which brings the total weight to over 19,000lbs. The trailer is still at least 1 1/2 feet taller than the back of the truck. I've gotten almost 13 mpg hand-calculated under ideal conditions, but usually get between 11 & 12. It looses a few more in the hills/mountains on the east coast. It's a time-consuming pain to fill fuel to the very top each time, but it's the most accurate way to check mileage. I usually cruise around 72 mph and, as noted, driving slower picks up mileage a bit. (The overhead computer has never been close, originally and even after a factory computer reflash for mileage, white smoke and computer mileage accuracy, especially after adding the box.)
It's all stock except for a Quadzilla 65hp/125tq tow box and an Amsoil EaA blue air filter. I believe they are more efficient than the oiled K&N and I've heard people debate whether or not the oil from it can actually affect sensors downstream. Drivetrain has all Amsoil: Series 3000 5w-30 diesel oil, Universal trans fluid, Severe Gear 75w-90 in the rear end and truck and trailer tires are kept between 75 & 80 lbs. The box picked up between .5 and 1 mpg. But I've always babied the truck and it has picked up mileage through 35,000 miles. It actually seemed to pick up more after a couple of occasions where I really got into the throttle! I "think" it's finally fully broke-in now after almost 50,000 miles. I also use Amsoil's diesel fuel modifer and cetane boost also.
I thought about a wing/spoiler on the topper, but am concerned about it eventually cracking the fiberglass. Some people have said that a wing at the cab is too far forward to help much. The "bubble" on the trailer front seems like a good idea and I wish I would have ordered it when I speced out the trailer.
I am considering an aftermarket, better flowing muffler and I've read that aftermarket fuel pumps help mileage also. Better flowing air boxes & tubes are suppose to help to. They are expensive and some people have swiss-cheesed their OEM air box instead.
The older trucks should get better mileage because the newer ones like mine have an extra pre-combustion cycle. I forgot exactly what it's called, but it uses a little more fuel. A manual trans should also get a little better mileage over an auto. Then there has been talk of "seasonal" fuel that affects mileage and there is always wind or unnoticable grades in the road.
I did get a 60 gal. auxilary tank and plan my stops in states with cheaper fuel prices. Flying J has good prices, online locations & prices and an RV card that saves 1 cent per gallon.
Amsoil source & info: http://www.thelubepage.com/
LOCOMOTION Racing
Old 12-10-2007, 11:20 PM   #6
DustyLowell
DustyLowell's Avatar
We have a 2004 Ram 4 door 2500 4x4 with the Cummins. Average mileage increased drastically when we purchased a 28ft Goldrush. We are seeing around 16-17 mpg towing to MapleGrove from NH.
Dusty Lowell
1773 F/SA
DustyLowell is offline   Reply With Quote
Old 12-11-2007, 12:01 AM   #7
james schaechter
Liked 1,436 Times in 299 Posts
I have a 2002 GMC Duramax 6 speed stick 2500hd 4 x4 crew cab. It has 3.73's. I usually tow at 2,000 rpm (70 mph) It is stock except a k and n filter and synthetic oil. I tow a 24 ft pace. No topper. I get 22-24 when not towing can count on 16-18 towing. Better if I slow to 60. The Vrib Bridgestones are 2 mpg better on the highway. I have 176,000 miles on the truck and have gone back and forth on this. They suck in the winter so I now have a set of more aggressive tires for winter and road tires for the summer. BTW, I pump the tires up rock hard when on a road trip towing in good weather. In the winter, the cetane booster seems to be worth it in terms of mpg and power. JIm.
James Schaechter 3163 STK
Old 12-11-2007, 04:53 AM   #8
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: Question on gas mileage
I have a 2006 Dodge 2500 with the diesel package and the automatic transmission. I tow a 30' 16000 pound trailer. When the Truck was new, I was getting around 10 to 12 mph. At about 25000 miles, I added a Super Chip (with the towing package) and a K&N air cleaner, the one that goes into the stock airbox. It helped the mileage from 12 to as much as 15 mph. I always have to go about 65 to get anykind of good mileage. If I go 70 to 72, the mileage drops down to as little as 10.5! That sucks... I plan on trying the external K&N air filter, which Larry Hill says will help more that the box type air cleaner. Larry Hill has a similar truck (Dooley) and he says he gets 16 +. I will gladley take 16 miles to a gallon. I think you are going in the right direction to improve mileage.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 12-11-2007, 09:15 AM   #9
neal noffsinger
Talking Re: Question on gas mileage
I have a 1995 chevy with a 454 it gets 6mpg no matter how what when and where!
Neal Noffsinger 3126 STK
neal noffsinger is offline   Reply With Quote
