Old 12-08-2007, 09:42 PM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face axle??
I'm also going to put a new set of axles in the car....right now it has stock axles with a moroso posi. I'm going to keep the posi for now.....also the car has C-clip elim.....question is Strange or Moser? or is their any differance?
Old 12-08-2007, 10:56 PM   #2
Uncrated
Banned
Default Re: axle??
Greg,
You know the Nova I have now and it has Moser axles and spool. In the past with other cars, I have used Strange or Mark Williams parts.
No question, when comparing looks, the Moser parts are in last place. The machine work looks ?coarse? and the spool is considerably heavier than Strange or Mark Williams. In addition, the right axle has excessive slack between the axle spline and spool spline.
I will soon be replacing the spool and axles with Strange parts. When placing the order, I will also upgrade to 5/8 studs. This allows using the thick washer and shouldered wheel nuts. I like the wheel nut retention much better than messing with the 1/2, street type ?mag? nuts.
Larry Woodfin
Uncrated is offline   Reply With Quote
Old 12-08-2007, 11:28 PM   #3
THE LEGEND
Default Re: axle??
Larry,
Was anything on that car good enough for you?
Greg,
Nothing wrong with Moser stuff.
Great Price!
Great Quality!
Great Tech support?
Great racers programs too?
In the car I sold Larry i bought the spool and axles. I had a local guy install them.
In the car I bought from Greg I ordered a complete rear from MOSER. It is a real nice piece.
Chip Johnson
THE LEGEND is offline   Reply With Quote
Old 12-09-2007, 12:14 AM   #4
Jeff Lee
Jeff Lee's Avatar
Default Re: axle??
Larry Woodfin
"great quality?" With that kind of fitment, Larry's doing himself a favor by replacing these parts. Sure Moser Guarantee's it's parts, but a broken rearend sure can play havoc on a race car! I prefer MW products but would have no problem with Strang products. I've never needed to replace rear axles, spools or ring & pinion gears thru 2 race cars in 3 different classes over the last 20 years.
Jeff Lee 7494 D/S '70 AMX
Old 12-09-2007, 10:47 AM   #5
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: axle??
You're 100% correct, there is a reason Moser came in the market with cheap stuff.
The Moser splines are broached, not rolled, and it's done AFTER heat treat, so you end up with sloppy fitting, soft splines.
A big issue?
Not really, I know a guy that cuts and resplines his own axles with a cut-off wheel, if that is what you want, go for it.
Check out Tom at Tom's Differentials, quality US made parts at realistic prices, and he has his own spools and axles done, because the Moser stuff is in fact junk. If the spline engagement isn't correct, you shatter side gears in a posi unit real quick.
http://tomsdifferentials.com
Dave Goob Cook is offline   Reply With Quote
