Old 07-07-2022, 09:35 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default FYI for 305 sbc racers
Talked with Dart today. The 305 little M block is no longer in existence. Discontinued. They are replacing it with a 305 SHP block but it will be at least 6 months before one is produced. Oh, and the part number changed and the new number is NOT on the approved list.
Little M 305 31151411
New SHP 305 31161411
jamie2370 is offline   Reply With Quote
Old 07-08-2022, 01:52 PM   #2
pmrphil
Liked 345 Times in 149 Posts
Default Re: FYI for 305 sbc racers
And from what I've been told the SHP blocks are now being cast in China
Phil Molski
PMR Performance
S/C 1623
Old 07-11-2022, 02:05 PM   #3
Liked 10,655 Times in 2,211 Posts
Would a sleeved 400 block work, it would have thick cylinder walls.
Old 07-12-2022, 07:43 AM   #4
Tom Johnston
Liked 22 Times in 6 Posts
I purchased a 305 Little M block in early 2020 but it was stolen out of my engine builders shop, and then Dart discontinued them. Now it appears they are making a new 305 block with a different part number.
I'm kinda new to all this, what is the procedure to get the new P/N approved? Can I initiate it or does Dart have to?
Thanks.
Tom Johnston 3177
84 Cutlass 305 L/SA M/SA
Tom Johnston is offline   Reply With Quote
Old 07-12-2022, 07:09 PM   #5
SSDiv6
Liked 1,538 Times in 575 Posts
Thanks.
The manufacturer has to submit the part for approval.
Old 07-12-2022, 08:23 PM   #6
pmrphil
The mains are a different size - I don't know if spacer bearings would be legal?
Phil Molski
PMR Performance
S/C 1623
Old 07-14-2022, 08:55 AM   #7
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: FYI for 305 sbc racers
Good morning to all,
I haven't done this myself - yet, but wouldn't a good 4" 350 block be a reasonable choice? Main bores are right size and the cylinder walls (once sleeved ) would be pretty thick as well without the cooling problems like cracking from the steam holes between the cylinder bores. Just my 2 cents from my little corner of the world!
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 07-15-2022, 05:26 PM   #8
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Respectfully,
^^^^What Henry Said^^^^
Sleeved blocks work very well if done properly. I have a 350 block that is sleeved and a 307 block that is sleeved. Personally, I think the 307 block is better as it was an early casting block and had very thick cylinder walls to start with.
I know that people say it costs too much or it's too much work to sleeve a block. But when you factor the cost of an aftermarket block and all the required machine work to true up every surface of a new block, I don't think those claims are valid.
But I'm old and my stuff is slow, what do I know
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 07-23-2022, 10:17 AM   #9
Rick J
Liked 73 Times in 37 Posts
Sleeving a larger bore block down will typically yield the best result.
Rick J is offline   Reply With Quote
Old 07-24-2022, 06:18 PM   #10
tscheerer
Liked 17 Times in 6 Posts
Is this the one you are looking for? Just noticed that it says out of stock.
https://www.competitionproducts.com/.../#.Yt3EtXbMKM8
tscheerer is offline   Reply With Quote
