Old 12-06-2007, 02:35 PM   #1
Ron Scott
Default Help
I'm in the process of sorting out a newly built 1986 Firebird for SS Gt class. Having been away from class racing for several years I would like to ask for some help.
The car is powered by a 250 horse sbc with a 2.08 first gear glide, a 5:43 rear gear and 29.5 Mickeys. It weights 3280 with driver. The best to date is an 11.0 -119 mph,1.56 short time. Since my last outing I have improved the converter to 5200 stall, added a victor jr.and new carb and found a suspension proplem. I have been told that low horse power cars need wheel speed in the first half of the quarter, with that said I am planning to change to a 5:83 or is this gear to much. I presently run through at 7200. any suggestions would be very helpful.
Ron Scott is offline   Reply With Quote
Old 12-06-2007, 03:36 PM   #2
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: Help
If your stall "improvement" was more stall, you should try it before you buy more gear, if you went the other way, I'd say the change sounds reasonable.
Good MPH, that thing is hauling.....
Dave Goob Cook is offline   Reply With Quote
Old 12-11-2007, 07:00 PM   #3
tim worner
Liked 126 Times in 20 Posts
Default Re: Help
I run the same combo and use a 6:00 rear gear and go thru around 8500. ATI makes a great convertor for that combo Call Cris and tell him you need one just like mine. I also use the short mickey. You might want to switch to radial.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 12-11-2007, 10:19 PM   #4
Jeff Goss
Jeff Goss's Avatar
Default Re: Help
What Tim said. He knows the combo.
You have enough tire. The radial is worth about .09-mainly because it wont grow at speed.
Stall should be 6000-6200. 6.00 gear is good. Should be 8000-8100 at the traps-higher if you really want to buzz the motor. 2.08 first gear is good. I ran a 1.98.
Work out that suspension. Not sure what you currently run for a rear end, but there are great products out there to get it to hook. You shouldn't spin the tire at all-you aren't making any torque.
Good luck!
Jeff
6990 SS/MA
Jeff Goss is offline   Reply With Quote
Old 12-12-2007, 06:18 PM   #5
Ron Scott
Default Re: Help
Thanks for the input.
I am currently running 5.43 gear with ladder bars and coil overs.
Don't realy want to buzz motor over 76-78 but maybe its to late to worry about that.
Old 12-12-2007, 09:59 PM   #6
Brad Potter
Default Re: Help
Which 250hp combo are you running?
Brad Potter is offline   Reply With Quote
Old 12-13-2007, 03:23 PM   #7
Ron Scott
Default Re: Help
441 heads, I may be off on the 250 horse in years passed thats what it was.
Old 12-13-2007, 07:27 PM   #8
Greg Hill
Liked 279 Times in 68 Posts
Default Re: Help
441 head is from a 69 350-255 which is rated at 294 or 295 in GT.
Greg
Old 12-13-2007, 08:41 PM   #9
Brad Potter
Default Re: Help
The classification guide still lists that engine at 290hp.
Old 12-14-2007, 10:13 AM   #10
bob d
Default Re: Help
you back in the Seat "Fire Chief Scott"? or is this Davids car?
bob d is offline   Reply With Quote
